show snmpv3 filter-profile
show snmpv3 filter-profile {[[hex hex_profile_name] | profile_name]} {param [[hex hex_param_name] | param_name]}
Description
Displays the association between parameter names and filter profiles.
Syntax Description
hex_profile_name Specifies the filter profile name. The value is to be supplied as a colon separated string of hex octets.
profile_name Specifies the filter profile name in ASCII format.
hex_param_name Specifies the parameter name. The values is to be supplied as a colon separated string of hex octets.
param_name Specifies the parameter name in ASCII format.
Default
N/A.
Usage Guidelines
Use this command to display the snmpNotifyFilterProfileTable. This table associates a filter profile with a parameter name. The parameter name is associated with target addresses, and the filter profile is associated with a series of filters, so, in effect, you are associating a series of filters with a target address.
The following command displays the entry with filter profile prof1 with the parameter name P1:
show snmpv3 filter-profile prof1 param P1
The following is sample output of this command:
Filter Profile Params Name : p1
Storage Type               : NonVolatile
Row Status                 : Active
The hex_profile_name and hex_param_name parameters were added in ExtremeXOS 11.0.
Platform Availability
